How to engrave lines
All  1-16  17-19
After struggling with projecting lines from the planks, and extruding groves, I think that flow is a better/easier solution, adding the planks to the top of the curved deck.
The scale of the grooves should maybe be greater than a physical model, to reduce the size differential? Current planks look good.
The current deck might be drawn as single surface, with the edges smoother?
Ah funny...never thought that was for a boat!:)
I had believed that will be for engrave something with letters!
So i will start for build an inversed boat's hull for have any form of engraving! :)
A boat floor deck is totally other thing!
I am not sure that the deck is longitudinally curvated!
It's generally flat! Flat inclined or domed laterally for evacuate water! ;)
EDITED: 8 Nov 2020 by PILOU
10027.19 In reply to 10027.18
Watching teak deck maintenance, repair and replacement is interesting.
The narrow teak planks are spaced with deliberate gaps. The gaps are filled with various materials, to prevent leaks. Oakum/pitch historically, with screws and bungs. Special caulk has been used. More recently, 9mm teak veneer, epoxy bonded, no screws nor bungs, with black epoxy filling the gaps. Steam bending.
Show messages: All  1-16  17-19
