Inset multiple faces of an object separately?
All  1-2  3-6
10020.3 In reply to 10020.2
Hey Pilou! Thank you for the informative answer. I have totally forgotten about sSplit.
sSplit produces non uniform border though! Sometimes you need that constant width along the perimeter.
I will surely experiment with sSplit more.
10020.4 In reply to 10020.1
Hi nameless,
> Is there a way to inset multiple connected faces separately instead of like a region?
Sorry no, not currently. I can add an option in for that once v5 is underway.
So Mutiple Offset should be possible with Elephant by Max Smirnov! ;)
10020.6 In reply to 10020.5
Thanks Pilou! I will check it out!
@Michael Ah I see. Thank you for the reply!
Well it's no biggie, but a tickbox adding the option would be awesome. And Scale could also have a tickbox for individual bounding box centers (like the ScaleIndividual script does right now). And let curve points snap to other points of the same curve when you move them around :-D On v5 ;)
Show messages: All  1-2  3-6
