Inset multiple faces of an object separately?
All  1  2-6
10020.2 In reply to 10020.1
You have _sSplit by Max Smirnov who insert any number of Faces/ Object selected! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
Works for the subdiv but can be used for anything else :) (_sBridge, _sSize )
See my Thread Subdivide in Nurbs :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
ps You have very more speed for select Faces of 2 object above: use Browser / Types Faces / Selection! :)
EDITED: 3 Nov 2020 by PILOU
10020.3 In reply to 10020.2
Hey Pilou! Thank you for the informative answer. I have totally forgotten about sSplit.
sSplit produces non uniform border though! Sometimes you need that constant width along the perimeter.
I will surely experiment with sSplit more.
10020.4 In reply to 10020.1
Hi nameless,
> Is there a way to inset multiple connected faces separately instead of like a region?
Sorry no, not currently. I can add an option in for that once v5 is underway.
So Mutiple Offset should be possible with Elephant by Max Smirnov! ;)
10020.6 In reply to 10020.5
Thanks Pilou! I will check it out!
@Michael Ah I see. Thank you for the reply!
Well it's no biggie, but a tickbox adding the option would be awesome. And Scale could also have a tickbox for individual bounding box centers (like the ScaleIndividual script does right now). And let curve points snap to other points of the same curve when you move them around :-D On v5 ;)
Show messages: All  1  2-6
