V4 beta Oct-27-2020 available now
 1-5  …  106-125  126-145  146-158
10011.146 In reply to 10011.145
Hi Ad, the local css part is not a separate .css file, it's embedded in a <style> element at the top of the .htm file.
So for example that one is in a <style> element at the top of the ShortcutKeysOptions.htm file.
10011.147
Question about editable points - if they will be added to script environment ? v4/v5 ?
- Tudor -
10011.148 In reply to 10011.147
Hi Tudor,
That's not going to make it in for v4 but I can put it in for v5 once the v5 beta process starts up.
10011.149 In reply to 10011.146
I already added the color option to the moi.css file, works fine. But thank you for pointing me in the right direction with the local css. Much appreciated.
Ad
10011.150
Here's a little regression, nothing very important, in the meshing option when exporting a file.
Emptying field like 'divide larger than' doesn't disable/reset the option anymore, you need to enter 0 to overwrite previous value and disable the feature.
I don't know if it's an intended behavior.
Sorry if it has already be reported.
Cheers.
10011.151 In reply to 10011.150
Hi PaQ, thanks I can repeat the regression over here. It seems that the previous behavior of emptying a field generating a 0 result automatically was kind of a side effect from something else but I should be able to restore the behavior purposely now.
Thanks for reporting it!
10011.152
Arg I'm right now so frustrated. I opened Moi beta after a few months of not using it. It told me the beta version I had was outdated. I downloaded this one, everything went well and my shortcuts were working without issues when I opened it for the first time, but today I opened the program again and my ini file was overwritten with defaults and I lost all my shortcuts. Ahhh crap this sucks... I had so many things, took me forever to put together these shortcuts. Has anyone else experienced this?
10011.153 In reply to 10011.152
Hi rolnxyz, I have not heard of any issues previously with the shortcuts spontaneously resetting.
Are you running on Windows? Try going to %appdata%\Moi and right-click on the moi.ini file there and choose "Properties". On there check the "Previous Versions" tab to see if there are any older versions saved from a previous Windows restore point backup.
That moi.ini file is where all that is saved, and that's also the file that would be good to save off to a backup if you have done a lot of customization.
Message 10011.154 deleted 5 Dec 2020 by BEMFARMER
10011.155 In reply to 10011.153
I tried restore yesterday, and realized I don't have the backups enabled. I just enabled them. I thought it would take me forever to get all of them back, I've been working and searching in the forums every time I missed a shortcut, and I got, at least the important ones that I used all the time.
If I reproduce the issue again I'll let you know. The only thing I remember changing yesterday was the unit from being unitless to use inches in preferences. I had the shortcuts in %appdata%/Moi on windows 10.
Also, this is one of my favorite 3d programs, best ux. Thanks for all the hard work.
Maybe you have also pressed button "Restore Default" against "Close" (for validate) in Options / Shortcuts ?
@ Michael : maybe will be a good thing to place the alone button "Restore Default" on the left bottom opposite corner ?3 times!
for avoid this ! :) I have made it alas 2 or 3 times!
10011.157 In reply to 10011.156
Hi Pilou, that's not a bad idea but pushing "Restore Defaults" pops up a dialog box and asks for confirmation, it doesn't do it immediately with just the one button press.
10011.158 In reply to 10011.157
Double security! ;)
Show messages:  1-5  …  86-105  106-125  126-145  146-158
