Hi Ad,
> One thing I noticed that the RIGHT MOUSE CLICK does not cancel commands, like line, circle and dimensions any more.
> I have to hit ESC or click the CANCEL button. V3 worked. This might be just a setting in the ini file, but I could not see
> any appropriate value to change?
Some info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9526.188
> Another issue I noticed was the CIRCULAR ARRAY. When I initiate the command, the focus is immediately
> on the ITEM COUNT input box, but the TAB key does not jump to the next input, it highlights the
> description (ANGLE). In order to change the value I have to mouse click the input field, after that TAB
> jumps to the following input fields.
This happens because the angle description is actually a clickable button that toggles between "Angle to fill" vs "Angle step" modes.
Currently the way the tab key works is if keyboard focus is on an input field it will go to the next control. If that's not the case (which it won't be if focus is on the angle label button) then it puts focus into the first input field in the command UI. So that results in the behavior you are describing here.
This is something that I would like to change, probably the rule should be if focus is on any control inside the command UI then Tab should go to the next field. It's too late to change this for v4 but I can do it in v5 once the v5 betas start up.
> I also had a question about the DIMENSION SETTINGS. If I create another present (additional to the default),
> it does not get saved unless I create a template file?
The "Default" preset gets stored in your moi.ini file and so that's globally available. Any additional presets are project specific and stored in the 3dm file that you save. If you load the .3dm file those additional presets will also load then.
> When I start a new file it opens with the default settings, although I saved it
> with the modified settings active. Is there a way to default to the new settings when I start a new file?
Yes, if you want your additional presets beyond "default" to be there when you start a blank new file you need to save a .3dm file with them set up how you want it and then specify that .3dm file as the startup template file under Options > General > "Template file". Then they will get loaded from the template file when you start a new file.
> Another thing, and this should probably go into a different thread? I installed the MODO INTERFACE and everything works fine,
> there is just one inconsistancy with the colors. On the DIMENSION TAB, the text color of the dropdowns for the values
> (e.g. settings for decimals) does not match the text color of all other TABS (e.g. GENERAL and so on). I could not find any
> settings in the css file, but I think this color might be pulled off from somewhere else?
Could you please show a screenshot of this area that has the inconsistent color?
Thanks, - Michael
