V4 beta Oct-27-2020 available now
 1-5  …  66-85  86-105  106-125  126-145  146-158
In 3D View seems the rule is not to click on vertex but on edges for better position dimensions wanted !
and move points after if needing!
EDITED: 11 Nov 2020 by PILOU
10011.107 In reply to 10011.104
Hi Chri,
> do you think that i use it like i should ?
I guess so - is there a particular result that you are not able to get?
One thing to note is that when you are drawing in the 3D view, the view direction plays a role in what plane will get used. It will be the one that is closest to facing you.
Here's an example - here I'm doing the same Dim Horizontal drawing command on the same points, but adjusting the view between uses to target different planes:
10011.108 In reply to 10011.107
"Plane" is depending of the rotation of the 3D view ?
Trick of the inclined selection avoid to rotate the view but there is no equal length of side lines...
I suppose that is not visible if lines are same color than volume for print ?
Indeed (but i have not Printed for see if "artefact" are visible or not!
10011.109 In reply to 10011.108
Sorry I don't understand this part.
10011.110 In reply to 10011.108
Rotating the view is how you control it, so it doesn't make sense to avoid rotating the view.
Yes, it's the same as drawing other planar shapes. For example the plane that a circle will use is controlled in the same way and has been for a long time:
Hope this helps!
10011.111 In reply to 10011.110
Yes I understand the Rotate plane! ;)
but
< it doesn't make sense to avoid rotating the view
it's losted time! :) I f you see video of Chris or mine we can draw any dimension in any positions
without rotate the 3D view's so the plane! ;)
Parts of Dimension who are overlapped will be not visible if all are black for example! :)
PS There is no thickness for dimension lines ?
10011.112 In reply to 10011.111
When you export a hidden-line drawing to PDF/AI format, you can set the thickness of dimension lines under "Line style options" > Annotations:
10011.113 In reply to 10011.112
Perfect !
And Fat Lines can be used for design purpose inside Moi It-self!
(here the curve is a 3D curve)
For Apply it (fat Lines) to dimensions just transform them (dimensions) in "object"
by the trick of Export / Import (dimensions ) in the in PDF format!
https://moi3d.com/forum/index.php?webtag=MOI&msg=10011.59 and following...
10011.114 In reply to 10011.107
HI Michael
Is there a particular result that you are not able to get?
yes
In the following file, using the view direction, it is easy to measure the x and y values (126.45 and 299.64) but not the z value
Is there a way to lock dimension axis (x, y or z), then click
on 2 points to create the dimension and a third point to place the result
Chri
EDITED: 12 Nov 2020 by CHRI
Size: 91.9 KB, Downloaded: 43 times, Dimensions: 988x561px
10011.115 In reply to 10011.114
Not perfect but something like that ?
Edit Frame from Bottom + Snap
10011.116 In reply to 10011.114
Hi Chri, for the z value one it would probably work best to do that in one of the elevation views rather than in the 3D view.
There is a way to do that, if you make a construction line you can then activate "Project next point" onto it:
10011.117 In reply to 10011.116
Ah damned I was very near the solution ! :)
Yours is very more elegant! (but i love also my Edit frame solution! :)
The helpers Lines are very powerful! ! The click move without release release must be a second nature! :)
And very cool use of the Project next point who was some mysterious is very enlighting here!
EDITED: 12 Nov 2020 by PILOU
10011.118 In reply to 10011.116
hI Michael
Excellent trick
the solution is to create a projection point before !
thanks
Size: 189.8 KB, Downloaded: 26 times, Dimensions: 391x385px
Size: 80.3 KB, Downloaded: 31 times, Dimensions: 860x604px
@ Michael : Your videos are not resized by the forum :)
Else last headache for be complete in 3D view!
Does it possible to draw a double arrow between A & B ?
I found but it's not direct!
Draw any dimension somewhere then Orient Line / Line Scaling: Stretch ! :)
(will be fine if numerical number will be front camera...if possible...
10011.120 In reply to 10011.119
Yes, the forum only knows how to resize images, not videos.
Well the dims are planar objects so you would need to make a construction plane that had the line between A and B on it and then you could create a dim there.
The essential job of a dimension is to label the projected distance between things, not the 3D distance between things.
Trying to label 3D distances is dangerous because it becomes easy to misinterpret the measurement.
So when you see a drawing that has this for example:
it should be this distance that is being labeled:
and not this:
10011.121 In reply to 10011.114
Hi Chri, also another thing you can set up to help with placing a dim in the z direction is put this on a shortcut key (like on the z key):
script: /* Snap to z direction */ var pp = moi.ui.getActivePointPicker(); if ( pp && pp.basePt ) { pp.restrictToLinePtDir( pp.basePt, moi.vectorMath.createPoint(0,0,1), true ); }
Then when you are drawing the dim after you place the first point you can push the Z key and that will lock it to the z direction and you can pick your other point. It's the same as making a construction line and activating "Project next pt" but just with one key press.
10011.122 In reply to 10011.120
Ok not a problem just that was curious the "Front View Camera", "align view" (?) was working for other dimensions
and not for this specific inclined one
(and very special diagonal view in only certain "Front" views) ...not vital! :)
Tricky the "Z" block! But not sure to well use...
seems that blocked the drawing of the vertical dimensions along edges in the 3D View ?
not only the one in drawing but next...
Even restart the prog and not re-using the Z shortcut...
here my shortCut used one time so the only thing I made...
I can't make this anymore ??? Vertical dimensions are not drawn in the vertical way like following! ???
OK that's return!!!
I suppose i had pressed "From object" button by error because i had not this inside dashed frame!
So now the "Z" blocker is working well! :)
Else
Seems Details don't access to these length...
But found again! :) Show Points and move them to the extremities arrows! Excellent!
The Edit Frame erase all when moved Points arrive to the Arrows! :(
EDITED: 13 Nov 2020 by PILOU
PS
Does it normal that the Helper Line / Project Next Point works only on a Snap Point
and not also along an edge/line under the mouse move "on" ?
10011.124 In reply to 10011.123
Hi Pilou, yes that is normal. That's because there are situations where the whole screen can be filled with an "on" snap especially for "on surface". If the point projection tried to use "on" snaps to then project it would make it difficult to track along the line.
Something like this for example:
10011.125 In reply to 10011.121
Hi Michael
Yes , with shortcut key it's quick and easy ( like M.O.I )
The next file is a GIF
EDITED: 13 Nov 2020 by CHRI
Size: 266.3 KB, Downloaded: 43 times, Dimensions: 399x372px
Show messages:  1-5  …  46-65  66-85  86-105  106-125  126-145  146-158
