Planar surface command
All  1-5  6-9
10000.6 In reply to 10000.5
Hi Marky, was it a DXF file that they sent you?
10000.7 In reply to 10000.6
- yes, it was.
Please find attached.
But I'm not sure if it's only a CDR export to DXF issue, as often I use an Archicad export to DXF procedure and experience the same issue.
I know, that from Archicad v. 20 there is a direct file export to 3DM, but I own only v. 19 which doesn't have it yet.
Marek
10000.8 In reply to 10000.7
Hi Marek, thanks for posting the file. That .dxf file will be imported ok with the next v4 beta, it has a fix for this problem.
10000.9 In reply to 10000.5
Hi Marky.
You can also use ai. Open a dxf with red dots, export it to ai, open or import ai.
Show messages: All  1-5  6-9
