Hi Michael and MoI forum,
I've seen this video a few years ago, this fellow has an algorithm to make voronoi wheels. https://youtu.be/gxkYTWuf0t8
Is there anything similar plug-in for MoI3D ? I would only need the 2D voronoi to be adjustable and easily modifiable . I would pay to use this plugin.
But that is a separate thing than the actual implementation of the Voronoi generator itself though, that looks like a quite extensive node structure. I am not aware of an existing implementation of that in the MoI node editor.
Any news ? I looked into node editing and it looks like this takes plenty of time to learn.
I design wheel spokes for my (scooter) bikes and I have plenty of physical labor to do besides the design process.
Any help would be appreciated :)
A quick DoyleSpiral node, with centers feeding Voronoi node.
Patterns vary with changing p and q and minMode and maxMode.
There would be a center zone to delete, and lines to delete outside of an outer circumference.
I'm out of posting memory, or would show a png :-(
Hi Frenchy Pilou. I am making these scooter bikes with and without electric motors.
I am really just learning how to convert bikes to electric. There is mid motor and hub motor solution, I made one with mid motor and I was not happy with the result.
Now I started a hub motor version, but my problem with wheels that have hub motors that those are tremendously ugly and has just boring good old spokes. So I came up with the idea of making my own custom wheels with custom laser cut or CNC'd wheel spokes. The one you see on the photos is the learner prototype, it's a MoI design that got laser cut from 4mm AlMg sheet then hand bent and assembled with a regular fixie bike wheel hub and rim. I am not sure what's the ToS about outside links, but I will post about it at ... you can google NIORbikes :)
I am getting some good results with Radial Pattern script, using it on a point and then Voronoi pattern, fat lines, extrude . (I only need the 2d lines for laser cutting though)
Thanks Brian, I still haven't figured out how to use nodeediting in MoI3d. I can add and use scripts , but I just need a day or two to sit down and keep doing it until I figure it out. I keep this thread open to come back to it .
I've got to this node editing today. Very interesting stuff. Now I want to figure out how to: Create a set of radial or random points that can be adjusted (like as with _radialpattern.js) then turn it to voronoi, then fat lines then round corners. Maybe it would be too much and it should stop at voronoi?
Larry's CenterPoints script has checkbox option to create the centerpoints of the circles (arcs), say of the _radialPattern script.
Then select the points, and run voronoi script.
So which to pursue? circleCenter script, or circleCenter node and/or radialPattern node, with center output?
Is there an old "get circle centers script" somewhere?
ps, A Doyle spiral with p=1, and q = ~24+, with voronoi applied to centerpoints, makes hexes which are only a little irregular.
Neat to see that the CenterPoints script might be helpful in an entirely unrelated context! The problem I was intending to solve with it is now being better dealt with by a more general Coordinates script that I'm almost done with, so I'll be happy to simplify the CenterPoints script to make it a more general tool for creating the center points and make the export of the coordinates optional. I will also remove the adjustment of the origin and axes as that isn't necessary in this context. When finished, I'll post it here.
