MOI3D Can develop the selection function of painting circle,like this
Vertex Tools
in Sketchup
selection au lasso ... ça doit être sympa
sinon le gumball aussi c'est agréable
Circular selection! ;)
I believe not yet implemanted but asked for a while! ;)
Hi hl, I do want to work on adding more types of area selection methods but it won't be for MoI v4 though.
Set a switch, turn off “ move” command, wireframe select the internal control point of the object, turn on“ move” command, is this method OK?
Hi FEIRUI445,
Sorry I'm not understanding the question - is that method OK for doing what?
When the point is selected inside the object, it is easy touch off the“move ”command. Can the move command be disabled? Turn on the move command after the selection.
Hi FEIRUI445, if you hold down shift+ctrl, you can then drag a window selection without object dragging happening on the first click.
Yes, I need it. Choose the inner point. Thank you!
In addition, sometimes the back control point is not needed. Is there any way to cancel it?
Hi feirui445,
Not automatically but if you go to a different view you can then do a Ctrl+drag window to do a deselection window instead of a selection window.
Thank you, very convenient
Hi feirui445,
Marco was working on a lasso select add-on a few years ago.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8830.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.33
Wayne
