18-37
38-57
58-77
78-97
118-129
OK, I think I get it! I have no idea how these small sections and slivers arrive though. How can these be removed?
What commands/scripts can be used to equally space the nodes, and how to smooth the curves fairer?
The original lines are here.
Thanks for the help!
In the past hull was drawn with flexible wood stick: that avoid little sharp curves! ;)
here not in wood! ;)
Esle when you ask "Show Points" you will see a red Square!
So multiple points are existing on the same x,xz place on the same curve !
So you must kill them
for example draw a little straight line for keep coordinates
kill all points then move the previous...
and kill the straight line! ;)
Then select the curve
Press TAB
write rebuild (Rebuild ReBuild etc... but without space) and give a reasonable number of points by familly curves
you can make a shortCut on this Rebuild function just write Rebuild on the second column!
Make some zoom for see if there are no much points in some place
So here in the back deck
You can kill N° 1 , not 2 it's the vertical line, 3
etc...
Then try to make very clean "patch" with intersection vertical horizontal and all will works fine! :)
Rebuilt it all now, but used fewer waterlines.
Now I want it as a solid, but the shell offset won't have any of it.
Gord
As the hull is difficult to close...
Just a little trick... ;)
More the hull and the line will be near better will be the result wanted... :)
That want not to say that the Hull is good but it's a solid! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/brede3.3dm
ps Not "Trim" but Boolean Diff of course else hull will be not closed! ;)
Hi.
Not sure I understand what is happening here.
G
About what ? If you have any question about the process don't hesitate!
It's very hard to correct a hull who has some defaults inside except all redraw...;)
So anyway for give an idea of the volume if you want make a 3D Print for any reasons
you can with your yet made hull make this trick above...
There will only few millimeters height difference between result and optimum wished! (1 or 2 mm)
As now it's a solid you can make any boolean operations you want for simulate the Shell
so
With the super cool free and easy one Simlab Composer Lite! (max 1920 *1080 )
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
Hi Gord,
It's the same thing I wrote above (
http://moi3d.com/forum/index.php?webtag=MOI&msg=9819.15):
quote:
Hi Gord, the shell command can only really handle thickening an open surface into a solid if it has all smooth pieces. When there are sharp edges like you have here the surface offsets do not touch each other and would need to be extended and intersected with each other and MoI's shell function is not good at doing that.
Additionally if you have any really tight bends or bumps in it that will be difficult for it to generate an offset surface from as well. An offset surface is generated by moving a distance away from the surface along its surface normal. If the surface normal is wiggling around chaotically it will become magnified in the offset and mess it up.
And also
quote:
3 sided networks can be problematic because the surface generated from it will have one of its sides collapsed down to a point and it is pretty easy for something with bends in it to then have really small tight bends in the collapsed down spot. Instead of a 3 sided network it is usually better to form areas like that by having a larger extended 4 sided surface that then becomes 3 sided by it being trimmed rather than trying to directly construct a surface to those curves. Then a fillet or blend can connect it to the other part.
The 3 sided network on the back has a chaotic wiggly mess at the collapsed tip area here:
The 3 sided network on the front has a chaotic wiggly mess at it's collapsed area too:
If you zoom in very closely to the tip area you can see that it has a lot of bumps and folds in it in a very small area:
Bumps and folds like that means the surface normal is changing wildly in a very small area, that will make the surface offset go crazy there as it tries to build something along the normal. The offset is kind of like taking a stick and sliding it along the surface, any wobbles or folds in the surface get magnified on the offset. So there isn't going to be any chance to get a good surface offset on stuff like that. In general I'd recommend avoiding making 3 sided network, you need to do things like make an extended 4 sided surface and then trim off some area like I wrote about previously here:
Your middle 2 pieces are ok, you can separate those out into 2 individual surfaces and use offset on those to get the thickening process going like I described above here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9819.16
Please explain what you did to make it all solid?
I have redone everything, so this is the hull before the decks are cut down.
Pefect just make the same that on my image above!
Create a solid box
Put the boat just a little inside
Boolean Union : you have a solid!
Draw a line any where you want but just under the box
Boolean Diff = you have your Hull solid
And you can now make a Boolean diff between your new hull
and the same hull some scaled
as shown on previous post
And after you can add 1 mm or more if you want! ;)
Move the face for make the little Shell
But all that because your curves were not perfect from the beginning...
A little shell
Else with your last file!
You can Loft each side one by one
At the bottom deck joint the 2 curves before the last Loft
Delete all curves
Join All surfaces
You obtain a solid! ;)
That don't want say that your deck is a pefect plane and your curves perfect curves! ;)
But you have a perfect solid! ;)
Hi Gord,
Unfortunately it seems like a step backwards in surface quality. You've now got a lot of separate surface strips that are not smooth to each other:
That's going to make it more difficult to generate offset surfaces to thicken it. You could try thickening it by directly modeling an inner wall instead of using Offset to make it like you could use if the surface quality was better.
The back end still suffers from 3 sided areas that are collapsing to a point while simultaneously trying to go a transition area.
As described above, usually these kinds of transitions are better to do as a separate surface using fillet or blend, rather than trying to construct a surface that tries to negotiate that type of shape change directly.
The triangular collapsed down to a point area here is not quite as chaotic and messy as previous versions, but it will still have problems trying to generate an offset surface from it. Offset surfaces have some general difficulty dealing with pole points where a surface edge collapses down to a single point. That's why I've been recommending over and over again not to try and model the back part this way.
If i can give you a little advice :)
Make some training with the method of the Post N°10
https://moi3d.com/forum/index.php?webtag=MOI&msg=9819.10
Like this you will have the good curves, learn to draw curves with the minimum of control Point
(better if you have same number of them by section)
And after you will create your own!
Bon courage!
OK, I understand about doing the stern differently. But how can I get a smooth surface rather than separate strips now? I've realised how to make it all a solid though, so at least some progress is made somewhere!
I realise I'm trying to do something too hard for my meagre skill level though!
G
Hi Gord,
2 things - you need to have smooth curves and you also need to build it as a larger piece instead of just one sub-section at a time.
See here for some description of why:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
Are the curves that were used to construct that in the file? It seems like there are a couple different sets in there.
Hi Gord, and yes this is a pretty difficult area of modeling, no doubt!
Thanks!
I think I need the waterline sections, at least one, to smooth it out. The plan I have to use does not have all the hull lines drawn. I realised a way to do this now.
G
Ok found an image of what i said previously! ;)
You understand with this system that you can't have sharp form! ;)
All is natural smooth line!
18-37
38-57
58-77
78-97
118-129
