Hi all,
Can you run moi3d in command line mode?
I'd like to basically automate import obj->subd->surface->export .stp
many thanks,
Misho
Hi Misho, yes you can pass in a script.js file to MoI as a command line parameter, then it will execute the script and can exit without showing the main window as it normally would.
See here for an example:
http://kyticka.webzdarma.cz/3d/moi/#Batch
perfect,
thanks Michael
