Full Version: White Rabbit CAD
Show messages: All  1  2-17
20 Apr 2020   [#2]
Cuty Prog !
@ Michael : Why I can't import White Rabbit PDF file inside Moi ? i can in another progs!
(not same figure than follow)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/whitetomoi3.pdf
20 Apr 2020   [#3] In reply to [#2]
It's because that PDF file only contains bitmap image data, not any vector curve data. MoI will only read vector data from PDF files.
If you open it in a different app like Adobe Viewer for example and zoom in to the curves you will see the pixels instead of a smooth vector outline.
20 Apr 2020   [#4] In reply to [#3]
Ah damned!
24 Apr 2020   [#5]
Sexy! ;)
8 Jun 2020   [#6]
New version ! ;)
You can now export as DXF and so import inside MOi!
Tailor Bezier
Cubic Bezier
26 Jun 2020   [#7]
24 Aug 2020   [#8]
Free Demo without Save & Printing
19 Nov 2020   [#9]
Updated version 1.0146, 1.0.147
25 Nov 2020   [#10]
26 Nov 2020   [#11] In reply to [#10]
Hi Pilou! Can the demo version export to MoI? If not, is this program worth it?
26 Nov 2020   [#12] In reply to [#11]
Sorry the Free Demo version can't save ! (but useful for training! ;)
• saving & printing disabled
DXF works now fine for import inside MOi...
It's a new sort of program some targeted on cloth making!
Ergonomy is very cool like Moi! ;)
So with some exotic functions ! :)
But for the moment for import something inside White Rabbit from Moi
that is not direct! (the PDF is not curves mode! For Print or image yes but not yet for modeler! )
So you must use the svg format! So something like that :
Moi--> DXF -->inkscape (free) --> SVG --> White Rabbit
Maybe a day there will be SVG inside moi! :)
By meka
12 Mar 2021   [#13]
New version 1.0.150 Mars 2021 https://www.tiesoli.com/whiterabbitcad/
12 Mar 2021   [#14]
Could it be used for sewing in Blender?
12 Mar 2021   [#15] In reply to [#14]
It's only a 2D prog for help the true traditional tailors to simulate their profession ...before the cuting fabric!
( or for any 2D design with its special funny functions )
It's absolutly not the same than Marvelous Designer who makes a 3D final result!
But you can use it for its cool UI to draw cloths in 2D that you can introduce in any progs ! (even Moi or Marvelous Designer or similar)
Maybe after convert the SVG or DXF format...
28 Mar 2021   [#16]
16 Jun 2022   [#17]
New Version 1.1.0
The PDF Export Import works now fine with Moi 3D ;)
