Show messages: All
1-3
4-10
Has anyone tried the free, open source BMOI Connector between MoI and Blender?
Github link:
https://github.com/TitusLVR/BMOI_Connector
Blender Artists thread:
https://blenderartists.org/t/bmoi-connector-bridge-between-blender-and-moi3d/1236834
It'd be great to have an easy way to send files back and forth between MoI and Blender, but sending from MoI to Blender is the most important to me personally, as I'm using MoI mainly to model hard-surface elements to be exported to Blender, including preservation of assigned materials.
Thanks.
yes I've got it setup and it works fine.
Barry
Great, thanks. Then I'm going to try it.
Tried BMOI Connector, and indeed, it works nicely.
Michael, I'd really advise you to consider adding such a bridge between MoI and Blender into MoI natively. I'm sure it will attract the attention of the rapidly growing Blender user base.
Hi Metin,
if you install Max's UI the BMOI Connector appears in the bottom panel.
Barry
Hi Metin,
Do you happen to know if it does work with windows 7 as well?
On the Github link it says it works with windows 10!
Thanks Barry. Yes, it took me a moment to discover those buttons, but the BMOI Connector bridge works quite nicely. Too bad it doesn't export curves as SVG to Blender. That's undoubtedly because MoI doesn't include SVG export yet.
Psygorn, I don't know if it works on Windows 7 as well, sorry. You'd think it should work, but the Github page mentions the necessity of the Temp folder's default path, so you might want to check if that path is exactly the same in Windows 7.
Show messages: All
1-3
4-10
