5-24
25-26
Hi Anthony, I've experimented with 3 other ones. The first one was one of the most well established ones. I found that ultimately it was too finicky handling surfaces with very slight errors in them. Like if a closed surface was more than 1/2 a degree off from being smooth it would refuse to construct it. It's also geared more for "enterprise" type higher cost software with high licensing fees. The second does not have those problems but instead it basically has the same problem as my current one where it isn't on track to get the approx 50 or so man years of focused effort needed to do filleting and shelling very well.
The third one is a little different, it's made by a single developer. It has been very helpful, it is the reason why MoI v4 has a new "best in class" sub-d to NURBS conversion function. It's going to help implementing some various interesting new functions in MoI in the future but I don't really see it as a replacement for the current kernel it's more for adding on some interesting new functions.
There is another one that seems promising and that I would like to experiment with in the future too.
Thanks Michael,
That's great to hear. Sounds like fun work. I look forward to v4 coming out.
Hi Burr, here's a plug-in that automates the extend-by-using-flow method:
FlowExtendSrf.zip
FlowExtendSrf worked well on a clothoid surface, and a plane.
I was wondering what is accomplished by the code:
while ( factories.length != 0 )
factories.pop().cancel();
A way to clear out the factories array?
So can be considered as an parametric Offset Surface ?
Hi Brian, yes that code will both clear out the factories array while also calling .cancel() on each factory. There's a separate factory for each selected surface and when a UI control has changed that is clearing out any previously displayed result before making new ones.
The JavaScript array object has a .pop() method on it which removes the last element in the array but also passes it back as the return value from pop() so it can be used in this way. This type of construct is called "function chaining" or "method chaining":
https://en.wikipedia.org/wiki/Method_chaining .
Another way to write it would be:
var factory = factories.pop();
factory.cancel();
or something like:
for ( var i = 0; i < factories.length; ++i )
var factory = factories[i];
factory.cancel();
factory.length = 0;
All of those would do the same thing, the pop method with chaining is just kind of nice since it's so compact.
Extend Surf : French Version somewhere on the page! ;)
http://moiscript.weebly.com/trucs-astuces.html
Yes, sort of - but usually in CAD that name "Offset Surface" means making a result that is displaced by traveling along the surface normal.
This one instead goes in the UV directions of the surface. You can also put in negative values.
"negative values" : never thougth of that! Very Cool!
yup, that'll do it!!!
Thanks Michael. No need to wait....
Really appreciate the work....
Seems this automatic extend don't works for the V3 !
Does this normal ?
Hi Pilou, it is possible to modify it to work with v3 - v3 needs to have temporary objects like the planes that are created to be added to the geometry database for async factories (like Flow) to be able to use them. V4 does not require that anymore, in v4 async factories can use "loose" objects (objects not in the geometry database) for input into async factories.
If you replace the Update() function with this below code then it should work on v3 too:
function Update( objects, factories )
var base_plane = CreatePlane( 0, 0, 1, 1 ).item(0).getFaces().item(0);
for ( var i = 0; i < objects.length; ++i )
var obj = objects.item(i);
var umin = moi.ui.commandUI.umin.value;
var umax = moi.ui.commandUI.umax.value;
var vmin = moi.ui.commandUI.vmin.value;
var vmax = moi.ui.commandUI.vmax.value;
var extended_plane = CreatePlane( -umin, -vmin, 1 + umin + umax, 1 + vmin + vmax );
moi.geometryDatabase.addObject( base_plane.getParentBRep() );
moi.geometryDatabase.addObjects( extended_plane );
var factory = moi.command.createFactory( 'flow' );
factory.setInput( 0, extended_plane ); // objects to deform
factory.setInput( 1, base_plane ); // base object
factory.setInput( 2, obj ); // target object
factory.setInput( 3, false ); // delete inputs
factory.setInput( 7, false ); // swap uv
factory.setInput( 8, false ); // Flip U
factory.setInput( 9, false ); // Flip V
factory.setInput( 10, false ); // Flip normal
factory.setInput( 11, false ); // Projective
factory.setInput( 12, false ); // Straight for projective
factory.update();
factories.push( factory );
moi.geometryDatabase.removeObject( base_plane.getParentBRep() );
moi.geometryDatabase.removeObjects( extended_plane );
Cool! But in what path file is this UpDate function? (for be sure)
I replaced the UpDate function in the FlowExtendSrf.js file. (or thought I did...)
Edit: Deleted this faulty post.
<< BUT, running the modified script in MoI3 resulted in (endless?) calculating process.
That was the same with the original for the V 3!
And the same with this update, (infinite calculus) there is surely a little bug somewhere...
Well the plugin only has 2 files for it, FlowExtendSrf.js and FlowExtendSrf.htm, and only one of those has an Update() function - FlowExtendSrf.js . That's the one that needs the new code.
It looks like the files in your FlowExtendSrfMoI3.zip are the original versions not the updated ones?
Here's the updated file attached.
FlowExtendSrf.js
Cool! I have missed the new version :)
Works even inside the Infinite Trial version 3 without save!
Thank you Michael.
I made the changes, but somehow the changes went sideways.
This is not the first time I have had trouble with Notepad++ when reusing and modifying copies of files.
I'll have to be more diligent :-)
No problem Brian! You might have gotten bit by a permissions issue. Files inside the c:\Program Files (x86) folder are restricted to be read only at the standard privilege level. If you right-click Notepad++ and use "Run as administrator", it will run at an elevated privilege which is then allowed to make changes to files in c:\ Program Files (x86)
5-24
25-26
