13-26
"negative values" : never thougth of that! Very Cool!
yup, that'll do it!!!
Thanks Michael. No need to wait....
Really appreciate the work....
Seems this automatic extend don't works for the V3 !
Does this normal ?
Hi Pilou, it is possible to modify it to work with v3 - v3 needs to have temporary objects like the planes that are created to be added to the geometry database for async factories (like Flow) to be able to use them. V4 does not require that anymore, in v4 async factories can use "loose" objects (objects not in the geometry database) for input into async factories.
If you replace the Update() function with this below code then it should work on v3 too:
function Update( objects, factories )
while ( factories.length != 0 )
factories.pop().cancel();
var base_plane = CreatePlane( 0, 0, 1, 1 ).item(0).getFaces().item(0);
for ( var i = 0; i < objects.length; ++i )
var obj = objects.item(i);
var umin = moi.ui.commandUI.umin.value;
var umax = moi.ui.commandUI.umax.value;
var vmin = moi.ui.commandUI.vmin.value;
var vmax = moi.ui.commandUI.vmax.value;
var extended_plane = CreatePlane( -umin, -vmin, 1 + umin + umax, 1 + vmin + vmax );
moi.geometryDatabase.addObject( base_plane.getParentBRep() );
moi.geometryDatabase.addObjects( extended_plane );
var factory = moi.command.createFactory( 'flow' );
factory.setInput( 0, extended_plane ); // objects to deform
factory.setInput( 1, base_plane ); // base object
factory.setInput( 2, obj ); // target object
factory.setInput( 3, false ); // delete inputs
factory.setInput( 7, false ); // swap uv
factory.setInput( 8, false ); // Flip U
factory.setInput( 9, false ); // Flip V
factory.setInput( 10, false ); // Flip normal
factory.setInput( 11, false ); // Projective
factory.setInput( 12, false ); // Straight for projective
factory.update();
factories.push( factory );
moi.geometryDatabase.removeObject( base_plane.getParentBRep() );
moi.geometryDatabase.removeObjects( extended_plane );
Cool! But in what path file is this UpDate function? (for be sure)
I replaced the UpDate function in the FlowExtendSrf.js file. (or thought I did...)
Edit: Deleted this faulty post.
<< BUT, running the modified script in MoI3 resulted in (endless?) calculating process.
That was the same with the original for the V 3!
And the same with this update, (infinite calculus) there is surely a little bug somewhere...
Well the plugin only has 2 files for it, FlowExtendSrf.js and FlowExtendSrf.htm, and only one of those has an Update() function - FlowExtendSrf.js . That's the one that needs the new code.
It looks like the files in your FlowExtendSrfMoI3.zip are the original versions not the updated ones?
Here's the updated file attached.
FlowExtendSrf.js
Cool! I have missed the new version :)
Works even inside the Infinite Trial version 3 without save!
Thank you Michael.
I made the changes, but somehow the changes went sideways.
This is not the first time I have had trouble with Notepad++ when reusing and modifying copies of files.
I'll have to be more diligent :-)
No problem Brian! You might have gotten bit by a permissions issue. Files inside the c:\Program Files (x86) folder are restricted to be read only at the standard privilege level. If you right-click Notepad++ and use "Run as administrator", it will run at an elevated privilege which is then allowed to make changes to files in c:\ Program Files (x86)
Yes :-)
Thanks a lot Michael for the plug-in ! It's great.
13-26
