Show messages: All
1
2-8
Hi Tony, can you please post your .3dm model file? Or if you want to keep it private you can e-mail it to me at
moi@moi3d.com
Hi Michael, I sent it on the email you provided me because it doesn't load me here .... gives me an error
I think this is the problem ... as you can see there is an error on the surfaces .... definitely caused by me :)
Hi Tony,
I think the error is that it was too large. If you delete all the hidden objects that would make a much smaller file size that should then upload here ok. But I've received it through e-mail so I'll take a look.
Hi Tony, so the immediate reason that it will not join is because there are gaps that are too large in several places, like here for example:
Those kind of look like what you get if you do a "rebuild" of a curve with a tolerance distance that is too low.
One thing that may be making things a little more difficult for you here is the small size of the model, it would be better for it to be either 10x or 100x larger in size so that individual features of your model are not so small.
Also another problem is some pieces are not very precisely aligned, like with these 2 surfaces here:
If I separate those surfaces and untrim them, the underlying surfaces look like this:
And then zooming in to this spot here there is a gap between those pieces:
Although that gap is small enough that it will allow those to be joined, it will make things easier in further steps if they were touching more precisely before they were joined especially with constructing more pieces off of them.
Thanks Michael .... how do you untrim the surface?
Hi Tony, you can untrim a surface boundary by selecting all the boundary's edges and then use Delete.
Check out here for some more description:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
Show messages: All
1
2-8
