Hello Michael,
Hope all is well.
I noticed MOI 3.0 will not launch on a newer OSX such as Catalina 10.15.2,
so I decided to embrace change and migrate to MOI 4.0. Does the build still have an expiration date?
Also, I use to have a great script for an object library widget that doesn't seem to work in MOI 4.0.
Any suggestions on how I could get this one resolved?
All the best,
Thanks!
-Berube
Hi Berube, MoI v4 is still not quite finished up yet. The available v4 release is a beta release so yes that means it has an expiration date. The current one expires on July 12, 2020.
Can you post the script so I can take a look?
A few scripts need some minor tweaks to run on v4, v3 ignored some kinds of syntax errors.
Hello Micheal,
Thank you for your reply.
As I researched to find the exact name of the script, I landed on this thread here that fixed my issue.
I was referring to the Custom UI script.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
So once again, thanks for your help. You led me down the right path from just asking.
Thanks!
-Berube
Hi Berube that's great I'm glad you got it worked out! Yes, the CustomUI script has a new version out to use with v4.
