Hello everyone.
I hope you're all doing well at work and such.
I use to have this great "Shortcut" in MOI 3.0 which would maximize (Full Screen) a panel in and out.
script: /* Maximize View */ if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) viewport.viewpanel.mode = viewport.name; }
It seems the syntax no longer works in the 4.0 Beta release.
Anyone able to point me down the right direction?
Thanks a lot.
-Berube
Hi Berube, that script you post is working fine for me over here in the v4 beta.
What is happening when you use it, any error messages?
Ah ok got it. The mistake was mine. Went form PC shortcut to MAC shortcut. Had to switch Cmd for Cntrl.
Thanks!
-Berube
