maybe that was already answered but I could not find an exact info.
I would like to change a perspective focal length from 50mm (if thats default) to on example 150mm or 200mm?
It would be awesome to have a shortcut for switching between a default perspective focal length and the custom one.
Thank you!
Hi angonyii, try this script on a shortcut key:
script: /* Toggle field of view */ var other_angle = 40.0; var v = moi.ui.mainWindow.viewpanel.getViewport('3d'); if ( v.projection == 'Perspective' ) { if ( v.fieldOfViewAngle == other_angle ) { v.fieldOfViewAngle = 27.5; } else { v.fieldOfViewAngle = other_angle; } }
Yes, the default angle matches to a 50mm focal length for a 35mm camera.
Works great! I hope it would be useful to others as well. Thanks so much Michael!
