moi\:CommandButton > div, moi\:CommandMenuButton > div, moi\:CommandSplitButton > div { display:none; }
<html> <head> <style> body { white-space:nowrap; } body > hbox { height:100%; -webkit-box-align:end; } body > hbox > flex, body > hbox > div { height:100%; } body > hbox > flex > *, body > hbox > div > * { vertical-align:center; } moi\:ViewTabs, moi\:CoordinateControls { display:-webkit-inline-box; -webkit-box-orient:horizontal; -webkit-box-align:center; height:100%; } .vspacer { display:inline-block; width:0; height:100%; } moi\:CommandButton > div, moi\:CommandMenuButton > div, moi\:CommandSplitButton > div { display:none; } <!-- Remove Icon Text The command above removes the text from below the icons of CommandButton.htm, CommandMenuButton.htm and CommandSplitButton.htm --> </style> </head> <body class="CommandBarBody"> <hbox> <flex> <!-- Include vertical spacer to make vertical-align:bottom work well with command buttons !--> <moi:CommandMenuButton menu="FileMenu.htm" icon="moi://ui/icons/File.png"><moi:Text textid="File"></moi:CommandMenuButton> <moi:CommandButton icon="moi://ui/icons/Save.png" command="save" rcommand="saveas"><moi:Text textid="Save"></moi:CommandButton> <moi:Spacer> <moi:CommandButton icon="moi://ui/icons/Undo.png" onclick="moi.command.undo();"><moi:Text textid="Undo"></moi:CommandButton> <moi:CommandButton icon="moi://ui/icons/Redo.png" onclick="moi.command.redo();"><moi:Text textid="Redo"></moi:CommandButton> <moi:Spacer> <moi:CommandButton icon="moi://ui/icons/Delete.png" command="delete"><moi:Text textid="Delete"></moi:CommandButton> <moi:SmallSpacer> <moi:ViewTabs> <moi:Spacer> <moi:CoordinateControls> <moi:Spacer> <vcenter> <moi:StateButton binding="value = moi.drawingAids.gridSnap" menu="GridSnapMenu.htm"> <moi:Text textid="Grid Snap"> </moi:StateButton> </vcenter> <vcenter> <moi:StateButton binding="value = moi.drawingAids.straightSnap"> <moi:Text textid="Straight Snap"> </moi:StateButton> </vcenter> <vcenter> <moi:StateButton binding="value = moi.drawingAids.objectSnap" menu="ObjectSnapMenu.htm"> <moi:Text textid="Object Snap"> </moi:StateButton> </vcenter> <moi:Spacer> <vcenter> <script type="text/javascript" src="customui/CustomInit.js"> </vcenter> <moi:Spacer> <vcenter> <moi:CommandButton icon="moi://ui/icons/ToggleLines.png" onclick="script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var edges = breps.item(i).getEdges(); if ( i == 0 ) hide = !edges.item(0).hidden; edges.setProperty( 'hidden', hide ); }"><moi:Text textid="Edges"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/ToggleHiddenLines.png" onclick="script:moi.view.showHiddenLines =! moi.view.showHiddenLines;"><moi:Text textid="HL"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/wireframe.png" onclick="var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }"><moi:Text textid="Wire"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/seledges.png" onclick="script: /* switch selection from a face to its edges */ var gd = moi.geometryDatabase; var faces = gd.getSelectedObjects().getFaces(); gd.deselectAll(); for ( var i = 0; i < faces.length; ++i ) faces.item(i).getEdges().setProperty( 'selected', true );"><moi:Text textid="SelEdges"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/nakededges.png" onclick="script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );"><moi:Text textid="NakEdges"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/ImportOBJExact.png" command="_ImportObj exact"><moi:Text textid="ImportObj"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/Node Editor.png" command="moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )"><moi:Text textid="NodeEditor"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandButton icon="moi://ui/icons/measure.png" command="MeasureDistance"><moi:Text textid="Measure"></moi:CommandButton> </vcenter> </flex> <vcenter> <moi:CommandButton icon="moi://ui/icons/Options.png" onclick="if ( event.ctrlKey && event.shiftKey ) { LlamaMode(); } else { moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' ); }"><moi:Text textid="Options"></moi:CommandButton> </vcenter> <vcenter> <moi:CommandSplitButton icon="moi://ui/icons/Help.png" menu="HelpMenu.htm" onclick="moi.launchHelp();"><moi:Text textid="Help"></moi:CommandSplitButton> </vcenter> <moi:Spacer> <moi:Spacer> <!-- <moi:CommandButton icon="Minimize.png" style="position:absolute; right:0;" onclick="moiWindow.minimize();"></moi:CommandButton> <moi:CommandButton icon="Restore.png" style="position:absolute; right:0;" onclick="moiWindow.restore();"></moi:CommandButton> --> <script> var g_InLlamaMode = false; function LlamaMode() { g_InLlamaMode = !g_InLlamaMode; var panels = moi.ui.getUIPanels(); for ( var i = 0; i < panels.length; ++i ) { var images = panels.item(i).document.images; for ( var j = 0; j < images.length; ++j ) { var img = images[j]; if ( img.parentElement.tagName.indexOf('COMMAND') == -1 ) continue; if ( !img.savedSrc ) img.savedSrc = img.src; if ( g_InLlamaMode ) { img.src = 'res://llamaicon'; img.style.webkitTransition = '-webkit-transform 10s linear'; img.style.webkitTransform = 'rotate(360deg)'; } else { img.src = img.savedSrc; img.style.webkitTransform = ''; } } } } </script> <moi:SidePaneTitleBar style="display:block;"> </hbox> </body> </html>
CommandBar.htm
CommandBar.htm
