11-30
31-50
51-70
71-90
91-110
111-130
131-150
411-425
James,
Can you holdup on including the new node into the zip file. There are some graphic updates that are being worked on.
Thank you,
Wayne
Thanks all working now.
looking good.
Message 9581.73 was deleted
Message 9581.74 was deleted
Updated ImgSample.js node at:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
CURRENT NODEEDITOR FOLDER updated with most recent version of ImgSampler:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
Cool and endless add to the my repository (no yet made...maybe this evening) :)
Hi Wayne and all,
thanks so much for your node, it is really cool!
Here is a small project I am currently working on:
The Go Gopher* Mascot from Google's programming language Go.
And the Image was taking from the Google folder on GitHub and
then redrawn with MoI, brought into the free ArtForm 4 to create
a relief and depth map from it. The depth map then was taken into
your node. Finally trimmed and scaled in MoI.
*Creator of the Go Gopher is Artist Renée French.
This is currently my progress:
And final model, hope you like.
Flatty personnage! :)
He he, :-)
And here is a final rendering:
Looks great Stefan! That is a charming character for sure.
Thank you Michael! It was a lot of fun to do this, because of MoI's easy of use and precision,
when it comes to modeling! I will also, at a later date, 3D print this little guy.
I am also very thankful that Renée`s Go Gopher has a Creative Commons License, otherwise
I had not done this model.
Best regards
Stefan,
Thank you. Gopher is looking good.
Wayne
Thank you Wayne.
Very nice Stefan :)
Thank you Marco.
Max Smirnov's Subdivide Classic for the Node Editor.
Based on his SubDivClassic script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.164
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.4
Save SubDivClassic.js file to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Wayne
What a task!
It was not that difficult. The code was already proven out by Max. All that was needed was to plugin the node variables along with a few MOI commands to avoid a nesting shell when subdividing an existing object. Other than that, it was easy... (Not really. I had trouble with it... :)
Wayne
11-30
31-50
51-70
71-90
91-110
111-130
131-150
411-425
