3-22
23-42
43-62
63-82
83-102
103-122
123-142
423-425
HI AlexPolo,
Just mouse click inside the picture frame to load an image. Set the resolution of the image before loading the image. It is the first released version. Improvements will made from user feed back.
I will check out the referances.
Wayne
Hi Finema,
Set the resolution of the knob, then reload the image. I will be making improvements on the interface.
Thank you,
Wayne
thanks Wayne, it's perfect !
good job !
Hi all,
I have red squares for reRange and PointExt :-( so I can't test it, unfortunately.
Where do I find those two and where do I have to install those?
I had this problem in the past too, with another node.
Is there an up to date alphabetic list of all required things for node editor,
where one can find all in one place, i.e. like a complete GitHub repository?
Normally last version of Node Editor is here managed by James
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
Thank you Pilou, that did the trick! :-)
Hi Wayne,
I have red square highlight on image sampler node and cant load image file. I have updated node editor to current version and placed node in correct location in USER/APPDATA/ROAMING location.
Something else missing?
Alex
Sorry, I had not yet updated CURRENT NODEEDITOR FOLDER to include ImgSampler.
Please reload with updated zip file attached to this post:
Have a great weekend
James,
Can you holdup on including the new node into the zip file. There are some graphic updates that are being worked on.
Thank you,
Wayne
Thanks all working now.
looking good.
Message 9581.73 was deleted
Message 9581.74 was deleted
Updated ImgSample.js node at:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
CURRENT NODEEDITOR FOLDER updated with most recent version of ImgSampler:
Cool and endless add to the my repository (no yet made...maybe this evening) :)
Hi Wayne and all,
thanks so much for your node, it is really cool!
Here is a small project I am currently working on:
The Go Gopher* Mascot from Google's programming language Go.
And the Image was taking from the Google folder on GitHub and
then redrawn with MoI, brought into the free ArtForm 4 to create
a relief and depth map from it. The depth map then was taken into
your node. Finally trimmed and scaled in MoI.
*Creator of the Go Gopher is Artist Renée French.
This is currently my progress:
And final model, hope you like.
Flatty personnage! :)
He he, :-)
And here is a final rendering:
Looks great Stefan! That is a charming character for sure.
3-22
23-42
43-62
63-82
83-102
103-122
123-142
423-425
