Show messages: All
1-2
3-14
"Discord is not so flexible and pratical than a forum"
I agree...but I think it's also nice to hace a place other than the offical forum, where MoI users can chat and share their WIP.
Message 9574.4 was deleted
How can I do that?
-Patrick
Just use Elephant! ;) Thx to Max Smirnov!
English/French
http://moiscript.weebly.com/biblio-elephant.html (for install, manual etc...by me )
Nothing difficult...it's the Revolve native function emulated!
I will make it as soon I have taken my diner! :)
So wait a little :)
So something like that...
Frame is the vertical axe X, Y, Z give of course values or 0,0,0 by default
Slider goes 0 to 360 with zero decimal so integer degre - Slider can have a Mini Maxi (you can all regulate)
At the end you obtain a Moi object absolutly normal! :)
this node following that you can reload! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/revolve_emulated.nod
Thank you! This looks like a fun new world to explore. Might solve a couple of issues for me as well. :)
Anybody to give me some quick direction here. I just went to rebuild this nod that frenchy shows (Revolve emulated).
I couldn't find how to add the "Output" node. I think I right clicked and went through all the options, but I could have missed it.
I can load the node frenchy links to and it works fine. Maybe I don't have a full node editor install? I haven't been following it well.
Thanks.
[EDIT] Found it. My NodeEditor window was sized down a bit, and the "Output" node, which is the upon start ofg a new project, was sitting, hidden off to the side. [EDIT]
Thanks again.
I am not sure if this has been discussed/requested, but on the concept design side, I would love to be able to use a mirror mode, where every move or action would be repeated on the other side of an axis/plane.
This would be gold in my opinion.
It's not yet the case when you make a mirror ?
Any modification (Add Pts Move... etc) of the original will be reflected to the mirror! ;)
Even you make something else between return to the original!
Hey Pilou! :D
Yes, mirrored objects can do that. But I would like to be able to boolean sub or draw polylines and have the actions repeated in symmetry without having to mirror each element. It could even be in ghost mode, just projection of the other half of the model or drawing to give you a sense of the whole. Is it dumb?
Hi nameless, that would definitely be useful. I want to have a deeper history function that could do that but there will be a whole lot of work involved in making that so I'm not sure when it will be able to happen. Maybe something for drawing could be done first before a full on history stack.
Hi Michael! The fact that you have your eyes on it makes me very happy :)
I think that it would untie the hands of many concept artists/illustrators that "think" while drawing. Being able to appreciate the design result of an operation without having to go through the steps of trimming and mirroring will be gold. And MoI has this ability already, to be very close to the intuitive drawing process and simplicity of lines on paper, so it would be a feature in accordance to its philosophy.
Thank you!
Personally I dislike Discord I have joined many groups on there and never found them useful mostly because the UI is all over the place I prefer this simple clean forum UI.
Slack is another that I find limiting even worse than Discord as it archives (hides) posts after a small limit is reached unless it is paid for.
At the moment I am on limited Internet connection so appreciate a low overhead site like this one even more.
Show messages: All
1-2
3-14
