Full Version: Extend / extrude "tangentially"
Show messages:  1-14  15-22
7 Nov 2019   [#15] In reply to [#13]
Hi Tom,
> I thought that you meant that is also possible extend a curve into "empty space",
> but this does not work, doesnt it ?
Empty space does not have to stay empty, you can draw in a temporary boundary object, extend to that and then delete the boundary object.
7 Nov 2019   [#16] In reply to [#13]
Hi Tom, also re: Extend command - the boundary object does not have to be a curve it can also be something a sphere or a plane.
7 Nov 2019   [#17] In reply to [#14]
When you say "Untrim" in this case of this tube what is untrimed ? Curve? Section ? Surface ? ...
Untrim is "Separate" ?
7 Nov 2019   [#18] In reply to [#17]
Hi Pilou, it's this surface here that would be untrimmed, the same one that wants to get extended:
To untrim it, use Edit > Separate on it first to make it an independent single surface not joined to anything else. Then select all its edges and do a Delete. The trimming boundary will be removed and the full underlying surface will be recovered.
The other end that will not be extended needs to be retrimmed.
7 Nov 2019   [#19] In reply to [#18]
OK!
And this
Extrude --> Boundary Sphere ?
7 Nov 2019   [#20] In reply to [#17]
> Boundary Extrude --> Sphere ?
I'm sorry I don't understand this question. The mention of a sphere above was about the Edit > Extend command, not the Extrude command.
7 Nov 2019   [#21] In reply to [#20]
Sorry I have read Extrude so now i better understand! :)
7 Nov 2019   [#22]
Always amazed by your support - very very helpful tips !
