I've searched but did not find an answer.
Is there a way to make the browser window wider?
I use long object names and I cannot see the entire name.
Thanks much.
Frederick
Hi Frederick, check out here for a script that you can set up on a shortcut key to toggle the scene browser pane between 3 different widths:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9266.35
It's also possible to edit the UI to change the default width:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7580.8
I will check them both out.
Frederick
