Show messages: All
1
2-7
Hi Tom, try using PDF format instead of AI, like this:
script:moi.geometryDatabase.copyToClipboardPDF();
When you export out from MoI set Scale = "Preserve units" and uncheck "Center on page". Then in Photoshop under Edit > Preferences > General uncheck "Resize Image During Paste/Place".
Over here that seems to do it, but it only seems to work for PDF format in the clipboard, not AI format. That seems to be a Photoshop problem, I get the same behavior with putting AI format in the clipboard from Adobe Illustrator as well.
Does not work for me - could it be because I
am using an older version of Photoshop ?
Hi Tom,
I was testing it here with an old version myself (CS2)...
I guess I'll need more details about exactly how you're trying to do it, are you possibly exporting a 3D perspective view projection instead of an ortho view?
Using CS4 and top view export.
Hi Tom, so it wasn't working over here it just looked like it with the object I happened to test with.
It doesn't seem like Photoshop CS4 or earlier is able to do that, I found a mention here that starting with CS5 there is a "Paste in place" function:
http://blogs.adobe.com/jnack/2010/04/paste_in_place_comes_to_photoshop_illustrator_cs5.html
Ok good to know !
Show messages: All
1
2-7
