Show messages: All
1-6
7-15
Here the French version! ;)
http://moiscript.weebly.com/r2d3.html
>Can you give a name to the "future new hole(s)" inside your code for an easy selection for make the last Diff ?
Yes! :-)
_ChangeHole.htm
_ChangeHole.js
Not yet tested but sure that will be excellent!
Merci!
Works fine
Many many Thanks to r2d3 and PILOU
Tested the new "Name": works like a charm!
Only little disturb about the all command: undo is not completly supported!
But it's yet a wonderful task!
PS You can "Copy" the "Hole Tool" anywhere you want before the last Diff ;)
Here the Hexagon on the Right is the final result of a move &/or scale of an original
You can easily Select by its name "Hole Tool" in the Browser Object by a Right Click
Now it is copyied 2 times on the Left!
Then the Last Boolean Diff can be made! (not supported by the command but it's not a big deal :)
And you can copy any separate hole (at the end they will have the same name so easy to select them!
So a new French version! ;)
@r2d3
Seems your wonderful prog don't works for wavy volumes ?
Have you some tricks or future ideas for that ?
Now it's the big manually DIY work! :)
This script relays on MOIs "SelfHealing" capabilities. Holes on curved or splited faces can't be selfhealed.
Need for Moments of Inspiration...
Have fun! ;-)
YES thats right...
@Michael Gibson > Do you have an idea ???
Hi Ralf,
I think that having an object that's created and then also deleted within the same command can mess up the automatic undo tracking.
Show messages: All
1-6
7-15
