Show messages: All
1
2-6
For in put something insert another one try the function Flow!
Hi piazzafatb, could you please post a .3dm model file with the name curves in it?
One thing that might be a help would be to put some kind of thin border around the text and then focus on surfacing that border down rather than directly using the text itself in the body part. That might help simplify the construction a little bit.
But if you could post a model file with the curves you want to use for the name that would make it possible to do some experiments.
Hi There
you can try it this way , the OV are just extruded and the LE are swept with the half round profiles.
but the results are a bit random where the end letters sweep to the outside profile
if you used 2 sweep lines you may be able to control them
cheers
shayne
LOVE.3dm
Shayne - I like your approach. It looks like you forgot to Boolean Diff the ring with the inside diameter circle, which will make the ring wearable by removing material under the L & E. I did that and was able to Boolean Union the entire ring. Looks nice.
2 sweep rails tidys it up without having to boolean out the inside
rebuild on the D section to match the number of points on the top letters also gives a better sweep
cheers
shayne
Show messages: All
1
2-6
