Show messages: All
1-13
14-17
At this time, the node info button is NOT working for the light color scheme.
I thing that basicFunctions.js ( I think Karsten wrote it?), applies to index.html, but NOT to index.html?scheme=Light?
The path to basicFunctions.js is %APPDATA\nodeeditor\node\extensions\libs\
Still puzzled,
So using the Info menu with light version was solved by Karsten back in March.
I forgot, and also lost the correction after my SSD failure a month or 2 ago.
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1398
So I made Karstens modification to basicFunctions.js so that the Info *.html box will appear in Light version of nodeeditor.
(commented out older code.)
(Backup of basicFunctions.js saved as basicFunctions.BAK, NOT basicFunctionsOld.js.)
Updating the Info *.html file for a node is not working.
The old *.html Info file keeps coming up in nodeeditor, even if the file is deleted.
It was working just fine a day ago... I only made a few minor changes...
Maybe a cache need clearing?
Reboot of computer did not help.
Closing MoI4beta did not help.
So if an old info *.html gets Stuck with the corresponding node, Press Alt+New on the nodeeditor screen to clear the old info .html file.
This must be some kind of correctable bug in the info code in a node?
Closing a node should sever its tye to its info *.node?
Is there a superior way to code the info files than with .html?
Show messages: All
1-13
14-17
