With only the "native" Nodes
first levels works fine but after...i must miss some trivial things! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/coq000.3dm
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/coq00.nod
Scale obliges to pass by Clone to Points...
Wanted the form itself...rotating around a specific point...for have a relative complex circumvolution :)
The "Up" introduced but some deflating volumes begin to appear :)
Up introduced
Elevation gives some deflates to the original volume...
The rotation with axis specified "Frame"...should be 0,10,0 for the "red point" above :)
Taken the form above "Flow" around a cylinder...
Free SimlabComposer
Free TwinMotion :)
Seems maybe i must use the Node Orient in the process! :)
and must also find the good X,Y rotations...
In fact no :)
Rest just the size who is always resisting a little! What a fight! :)
The UI is very elegant (click the image follow ;)
Alas not yet the perfection!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2gliches_nodes.3dm
For surely a trivial error! :)
With an antother profil...the braun one is a reflexion of the golden one! :)
