Show messages: All
1-3
4-7
Thanks guys for your help and such a quick reply,
I checked all the shortcut commands and indeed they were either missing a _ or had minor typos. Most of the scripts are working now.
As for the script with a button, I believe it's called _Subdiv_beta9.js and it looks like this (screenshot from a youtube tutorial attached)
Thanks again!
Hi Bruno, that button is a built in part of MoI v4, you can get it in the v4 beta release at
http://moi3d.com/beta.htm . It's for loading sub-d objects from .obj files and converting them to NURBS surfaces in MoI.
For this forum thread I have some question:
Whats the difference between Moi V4 with sub-d obj importing and converting them to Nurbs and ImportObj script?
Down below attached picture of the obj file imported with ImportObj script.
As I do understand with sub-d import and converting to Nurbs would not be so many polygonal planes on the cup im I right ? And loading obj. file time will be much more shorter?
A few days before i bought Moi v3 and want to stick to that, but if many new cool features a better in V4 i will upgrade if needed.
Thank you for an answers.
K.
Hi Konni, the new v4 sub-d importer importer can make larger surfaces and also has a higher level of smoothness between surfaces.
It is meant though for importing not just any kind of .obj file, it's only meant for loading a file that has been set up for subdivision smoothing.
If you purchased MoI v3 within the last year then you will be getting a free upgrade to v4 when it is out, so I'd recommend using v4 now. You can get the v4 beta at
Show messages: All
1-3
4-7
