Hallo!
Is there a way to copy the file path of the last opened files? It will be shown when the mouse is over it.
It would be very practical at times.
Thanks in advance for a tip.
Franz
Hi Franz, sorry no there isn't any way to copy the full file path to the clipboard from that UI. But you can find the full path listed in the moi.ini file in the [Recent Files] section.
Hi Michael!
Thanks for the message.
It is possible (windows 8) to display and execute the last used files in the "recent-folder", or to copy the folder path. However, i haven't found out yet how to increase the number of saved files in order to be able to access them further (search for "3dm").
Best regards
Franz
Hi Franz,
If you mean the list in MoI's File menu like you show above, that can be set in moi.ini under:
[UI]
MaxNumRecentFiles=15
Hallo Michael!
Thanks for the advice.
It's great what possibilities there are. Good for orientation if you draw a lot and are a little tired the next day...
Best regards
Franz
