Show messages: All
1-4
5-11
Hi Mik,
Could you please explain how you created this surface?
Hi Stragazer,
I've used Network command together with set of curves.
Hope this helps.
Fiona Basin Mixer_Surface modelling.zip
Hi Mik,
Thank you for the detailed explanation. I appreciate it.
Hi Mik,
great job! and great explanation.love what you did in the complex curve area.
Hi neilwilson3412,
thank you very much for your kind words.
I wasn't sure from attached photo, if front surface of mixer is flat or curved, but it seems from another photo
https://www.sinkwarehouse.com.au/products/fiona-basin-mixer-black/, that surface is flat, therefore i decided to use that procedure, only as an exercise, but it exists more than one solution of course.
I like the Ed's attempt.
Ciao
Mik
"... but it seems from another photo
https://www.sinkwarehouse.com.au/products/fiona-basin-mixer-black/, that surface is flat"
That's a much better photo and line drawing. On the original silver photo I was seeing slight curvatures, which made the front face more complex to model.
well done ed!
sorry i didnt respond sooner!
the image is tough to see the under belly curvature. i will be having another go today.
neil
Show messages: All
1-4
5-11
