hi guys.
challenge_001:
make this in Moi
number one rule to determine the winner will show the cleanest and most elegant approach.
Don't be FOOLED this wont be as simple as you think.
Message 9478.2 was deleted
... first kick off :-)
Fiona Basin Mixer.zip
EDIT: Here's my 2nd attempt. I was not happy with the front face in front of the aerator on the first attempt. New images uploaded below. Rendered in KeyShot.
Hi Mik,
Could you please explain how you created this surface?
Hi Stragazer,
I've used Network command together with set of curves.
Hope this helps.
Fiona Basin Mixer_Surface modelling.zip
Hi Mik,
Thank you for the detailed explanation. I appreciate it.
Hi Mik,
great job! and great explanation.love what you did in the complex curve area.
Hi neilwilson3412,
thank you very much for your kind words.
I wasn't sure from attached photo, if front surface of mixer is flat or curved, but it seems from another photo
https://www.sinkwarehouse.com.au/products/fiona-basin-mixer-black/, that surface is flat, therefore i decided to use that procedure, only as an exercise, but it exists more than one solution of course.
I like the Ed's attempt.
Ciao
Mik
"... but it seems from another photo
https://www.sinkwarehouse.com.au/products/fiona-basin-mixer-black/, that surface is flat"
That's a much better photo and line drawing. On the original silver photo I was seeing slight curvatures, which made the front face more complex to model.
well done ed!
sorry i didnt respond sooner!
the image is tough to see the under belly curvature. i will be having another go today.
neil
