Show messages: All
1
2-20
Hi Neil, I'll need a little more information on how you want the script to function. Like in your screenshot you've got 20-something styles there, how should the script determine which particular style you want to target for selection?
sorry Michael.
i just want the function to select faces with in a solid the same as you can do from pushing the yellow selection circle.
just that script so i can pick a style press a hot key and that script will run without having to move my mouse over to that tiny little yellow circle.
Hi Neil, re:
The part I don't understand is the "pick a style" part, how do you want to pick the style?
hi,
maybe could try the SelectStyle script..
http://kyticka.webzdarma.cz/3d/moi/#SelectStyle
thanks for the suggestion... i have this script and use for object selection......however im looking to achieve the same result on a sub surface level within a solid ..the script you recommend does not perform that operation.
hi Michael,
i really hope this explains it better .... i was hoping it would be quite simple....
Thanks Neil, yes I think I understand now. Please try this script, does it do what you need:
script: /* Expand selection over same styles on sub objects */ var styles = new Array(); var parents = new Array(); var sel = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < sel.length; ++i ) { var obj = sel.item(i); if ( obj.selected ) { styles[obj.styleIndex] = true; } if ( !obj.isTopLevelObject ) { var par = obj.getTopLevelParent(); parents[par.id] = par; } } for ( var i in parents ) { var subobjs = parents[i].getSubObjects(); for ( var j = 0; j < subobjs.length; ++j ) { var subobj = subobjs.item(j); if ( subobj.isFace && styles[subobj.styleIndex] ) subobj.selected = true; } }
Michael your a legend !!!!!!
it work perfect!!!!!!
thank you so much!!!
That's great Neil, you're welome!
does this old one for V2 "On objects" works also on V3? (seems yes but want to be sure! :)
script: /* Extend the selection of objects with the same style */ var objects = moi.geometryDatabase.getObjects();var styles = new Array();for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }
Hi Pilou, yes that one works ok on v2, v3, and v4.
else i have a bug with the "sub-object" ?
else does this normal ?
after boolean Diff of a blue sphere from a Red Cube i have the "generative arc circle" on the result ?
So 2 "facetts" on the result!
It looks like that's from your changes with editing the comment part of the code, script code can only have ascii characters in it.
That's a normal result if that was where the closing "seam" edge of the sphere was at.
"Seam's sphere" yes it's :)
So i suppose to rotate it before boolean Diff can solve this little disturb...
else
I correct the "sub object bug" in pasting your "English script" inside the "ShortCut" Moi editor and change comments directly !
(even with accents)
That works! :) I had previously copy / past the text from another prog... maybe this explain that! :)
hi Michael,
can you make another script to do the same for edges that get assigned a style.
Hi Neil, re:
Sure, please give this one a try:
script: /* Expand selection over same styles on edge sub objects */ var styles = new Array(); var parents = new Array(); var sel = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < sel.length; ++i ) { var obj = sel.item(i); if ( obj.selected ) { styles[obj.styleIndex] = true; } if ( !obj.isTopLevelObject ) { var par = obj.getTopLevelParent(); parents[par.id] = par; } } for ( var i in parents ) { var subobjs = parents[i].getSubObjects(); for ( var j = 0; j < subobjs.length; ++j ) { var subobj = subobjs.item(j); if ( subobj.isEdgeCurve && styles[subobj.styleIndex] ) subobj.selected = true; } }
nailed it thank you!
Show messages: All
1
2-20
