It could be interesting to have a command that would move an object in front of another depending of the view and add padding space.
This would be very useful for example when cutting booleans with curves, projecting curves, etc
Lets say you draw a line to cut a solid but it's intersecting and won't work well.
This would bring the curve "over" the solid and prevent changing views, move etc...
It could behave like a visual stack, move to front or to back.
Just a little productivity detail.
Marc
Hi Marc, so at first I was thinking you meant something that would just change the display of an object only so it drew over top of another object. So I was thinking of that for a little bit.
But now that I read your message again I think you mean moving the object like Transform > Move is that correct?
Would it be for moving curves only?
Maybe if you select both the curve and another surface or solid it could move the curve above that other object or if you selected just curves it would move it above everything?
""""""""" I think you mean moving the object like Transform > Move """"""""
Yes, this is what I had in mind.
""""""""" if you selected just curves it would move it above everything """""""""
Yes, like that. Maybe this would be useful for other kind of objects but I can't think of anything right now.
Marc
Hi Marc, I think it should be feasible to do a plug-in for that. I'll give it a try tomorrow.
Maybe a similar thing would be to have a kind of temporary construction plane move so when triggered it would move the construction plane above the selected object or all objects with projection turned on so that when you draw something it would go in that "floating above" layer from the start? Then maybe it would automatically reset after you had drawn anything...
Hi Marc, also here's what the detailed object properties looks like at the moment:
This was basically a prerequisite for dimensions since there are going to be a quite a lot of properties on dimensions to tweak. But since it would be weird if only dimensions had stuff there I'm getting stuff for other objects filled in there too now.
Just yesterday got the type tallies working pretty well and today I was thinking it could work well to be able to click on any of those labels to filter selection down to those.
"Open" are like "Naked" ?
Hi Pilou, well for curves open means the curve has a start and end point that do not touch each other. For surfaces yes open means it has naked edges in it unlike a closed solid.
That also reminds me that I want to add a total count of edges of solids/joined surfaces/surfaces in there as well.
The idea for the temporary plane is very good, but I often realize after the fact that a cut won't work.
I don't know if a tick box in the boolean operation like "project curves outside" would make some sense or would just be confusing. It could only appear when curves are involved in the party.
The filter idea in the detail properties is very interesting.
Maybe objects could highlight as you hover their name (red?), with a little dot like the other panels.
Weren't the advanced properties planned for v5?
Marc
Hi Marc,
> won't work.
I would like to have some more options for curve cuts. The next time you happen to run into this could you please save it off and send me the .3dm file? It would be useful to have some examples.
Maybe... But I kind of worry about having too many different colors used for feedback.
Yeah but having the detailed properties dialog has turned into a prerequisite for dimensions since there are a quite a lot of them.
It's kind of like when you pull on a thread and get a whole lot more stuff than you expected.
sounds great!
Ok, I will send you files when the same situation appears.
""""""""""It's kind of like when you pull on a thread and get a whole lot more stuff than you expected.""""""""""
Stop pulling ! ;)
Marc
Hi Marc, I've attached a try at a move in front command. Does this do what you were originally thinking?
> Stop pulling ! ;)
but but but just one little pull, it's hard to resist! :)
MoveInFront.js
Jes, that's exactly what I was thinking at the start, thanks!
Marc
