Is there a way in MoI to measure the surface area and volume of a solid?
Very often I have to estimate the weight of some things, because it is related to structural calculations and shipping cost.
Thank you,
m
Hi Marky, there isn't currently a built in way but there is a plug-in you can install to get that.
To get it go to Max Smirnov's file archive here:
http://moi.maxsm.net/media/files/ and on there find the one named CVolume.v.2.0.2015.09.27.zip . There are instructions for how to install a plug-in on the FAQ
here.
There are also various STL viewing programs that should be able to calculate that for you as well.
It is something that I want to add as a built in function in MoI in the future.
OK, Michael,
Just found this thread also, thank you anyway.
Having that function in MoI would be great.
m
Wow!
This script is great!
It shows even a specific density related to some materials!
That's exactly what I needed.
Fantastic application and community.
Thank you.
The only thing to remember is that with the c volume script that it calculates the volume of each selected solid and adds them together and if they overlap or intersect each other it can return a slightly high result.
cheers
shayne
"..it can return a slightly high result"
- Anyway, it's safer than undervalue.
marek
