Full Version: Moi 3d v4 and rocket 3f
30 Jul 2019   [#1]
Does moi 3d v4 support the rocket 3f “sand to moi” script? keep the crease effect ? I know moi3d v3 support this cript but no crease.
If it can, then this workflow will be great. (rocket 3f +moi 3d----subd+nurbs);
(My English is not good, I don't know if you can understand it.)
30 Jul 2019   [#2] In reply to [#1]
Before I remember if it's possible, you can export your creased object in OBJ format from Rocket 3F and reload it inside MOi by SubDivision / Create from a file...you will have your creased edges!
30 Jul 2019   [#3] In reply to [#1]
Hi weiji, sorry I'm pretty sure it will work the same as v3. I don't think edge weighting will come over.
OBJ files do not have any mechanism in them to support edge weights.
30 Jul 2019   [#4]
Script don't keeps the creases...
But the method writed above keeps the crease! ;)
16 Sep 2019   [#5]
New version 1.7.1 with always a free version possible! (Direct Bridge with Moi3D in the 2 ways)
https://rocket3f.com
17 Sep 2019   [#6] In reply to [#5]
Great software Rocket3F.
Very underrated but a great software.
16 May 2020   [#7]
I had a little problem export Import Moi <--> Rocket 3F but with reloading last version of Bridge !
All is perfect !
So more easy !
In Rocket Select something Subdivided or Not : Press the Icon "MOI" (or CTRL + Alt + A)
In Moi : Select Something Subdivided or Not : CTRL + Alt + A
That all!
16 May 2020   [#8] In reply to [#5]
I think it is Rocket3F v 1.7.3:
https://www.rocket3f.com/kunena/updates/1001-version-1-7-3#5408
regards
Ken
16 May 2020   [#9]
With the last Bridges all works like a charm!
Just Press Ctrl + ALT + A when you are in MOI
Just press the Moi Button when you are in Rocket 3F!
16 May 2021   [#10]
https://www.rocket3f.com/downloads/Rocket3F_Portable_1.8.rar
Portable version of this free retro futurist modeler! ;)
17 May 2021   [#11] In reply to [#10]
Hallo Frenchy,
I unpacked it, but it won´t run.
17 May 2021   [#12] In reply to [#11]
I believe that you must free registered!
