Does yet existing distributions following differents serial ? (functions, plugin or nodes)
For place objects with less regularity
0 1 2 3 5 7 11 13 ...
0 1 2 3 5 8 13...
0 1 2 4 8 16 32...
0 1 2 3 6 18 108...
etc...
There is this but...
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8503.1
Hi Pilou, I don't know of anything that does that currently but maybe the ScriptArray command could be adapted for that.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
Or maybe if it is spacing between already existing objects you want to target some modification of the Distribute command:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.13
I'm not entirely certain what it is you're trying to do - replicate one object at an increasing interval?
Yes something like that...
https://rawandrendered.com/modularity
From a Camacho image above
If you see the Vertical and horizontal repetitions the inbetween objects are some regular (except the front vertical corner) ...rythmed... but objects itselve are irregular
I want add "variation" of the gap itself...like in the prime number list or purelly randomized . .. ... ..... ....... ........... :)
Maybe the Elephant will be the best solution ... some cursors for Move away/ Bring nearer some objects different or not...for avoid to bricolate in the code! :)
A sort of differential ExplodeMove...a randomized distribution
For simulate different gaps: display random number of objects on their positions from a collection
Node random Obj is existing
not yet exactly that i wish :) the gaps 1 3 1 1 1 2 result must be on each object
Hi Pilou, what about just drawing it how you want it?
Will be easy for few number of objects but not over 10-15 objects and in different directions! :)
I am more confident on the machine!
Hi Pilou, yes maybe something to try with Elephant then?
Objects Selected is existing
Classic Random is existing
Move is existing
Display is existing
Not sure about the "one by one"...and the "loop / return"
Hi Pilou, sorry I don't have enough experience with the node editor to be able to help you with that very well.
No problem i will post on the forum node player! ;)
