Full Version: Render Moi object online! free
Show messages:  1-6  7-24
12 Jun 2020   [#7] In reply to [#6]
comment exportes tu de MoI pour que ce ne soit pas facété ?
merci
12 Jun 2020   [#8]
I tested with .obj files and .iges.
I dont see hard facetted render.
When I export, I usually have many faces. Here, more than 14000.
Very fast render. Here about 2 seconds.
J'ai testé avec du .obj sortant de MOI3D et IGES.
Les facettes n’apparaissent pas.
Il faut dire que le nombre de facettes est important sur mes modèles lorsque je les exporte.
Ici 14000 triangles.
C'est assez impressionnant au niveau de la vitesse du rendu... 2 secondes ici.
12 Jun 2020   [#9]
My objects have 6 000 faces and welded...by default...no special regulates
12 Jun 2020   [#10] In reply to [#9]
But you test online or standalone
On mac i can't download the standalone and with the web version here what I see when i open Light tracer Render
12 Jun 2020   [#11] In reply to [#10]
Have you seen if your Graphic card is compatible
"Light Tracer can run probably on any GPU produced after 2013 (please download the latest drivers!)."
13 Jun 2020   [#12] In reply to [#11]
Thanks Pilou
my graphic card is : AMD Radeon R9 M395X 4 Go graphismes on iMac (Retina 5K, 27 pouces, fin 2015)
but it's not a matter because i use keyshot 9 for professionnal renders and the great free Blender for for speed render with EEVEE
13 Jun 2020   [#13] In reply to [#12]
So maybe try the Discord Light Tracer!
https://discord.com/invite/7gAsv9q
31 Aug 2020   [#14]
New version! 1.6.5
31 Aug 2020   [#15] In reply to [#14]
giving it a try now it seems really slow and did not import all of the formats i thought it could...anyway lets see, maybe it might
be done 'later' ;o)
What is the best 'not too expensive' renderer for moi3d users in your opinion Pilou?
31 Aug 2020   [#16] In reply to [#15]
My 2 favorites are the free Real Time Render SimLab Composer Lite ! (max 1980*1040 )
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx?utm_source=free_tools
Super easy : accepts quasi all 3D formats (except 3DM from Moi so take OBJ from Moi)
So you can import and mix many different things!
And the Free TwinMotion 2019 - 2020 without any limitations - terrific simplicity and such vegetations wind, snow, ocean animation's camera etc...
( free if you had downloaded the 2019 by Epic Games) who is even more easy if possible!
1 Sep 2020   [#17]
Another one! For the Moi SPK exported models ! ;)
A free version is existing!
https://www.coohom.com/
8 Sep 2020   [#18]
No render online...
Bella Render Free in 1280*720 Integrated in SketchUp, Rhino, Maya or in Standalone
https://bellarender.com/
For the moment for the OBJ import you have to put all the files on the same path level! Mesh, Mtl, texture... etc
10 Jan 2021   [#19]
CadRays is also cool!
https://www.opencascade.com/products/cad-rays/
20 Nov 2022   [#20] In reply to [#18]
I've never heard of this render farm before, so far, I've been using https://rebusfarm.net for the longest time... which is why I was going to recommend it here, if you get the chance you should check it out too, they really have one of the best render farms I've seen, really fast and really affordable.
21 Nov 2022   [#21]
Can maybe useful! ;)
Not sure it is in the free Web version... (verified...it's not! :(
21 Mar   [#22]
Not exactly a render but...
CGDream
https://cgdream.ai/
Free 20 images / Day, 1024 x 1024
252 Filters (5 maxi), 5 enhances / Day
import 3D GLB, FBX (so moi3D!!!
Filter Sc-fi : 1.00
Vizcom same prompt, (very complex colored transparent engine)
6 renders engines 100%, same start image (CGD), last 4 Refine, 90,50,3,10 %
But Vizcom can make the same : import a 3D object directly inside and render it!
21 Mar   [#23]
Vizcom free + import volume 3D OBJ (from Moi3D) :)
A prompt + an image as style!
2 Apr   [#24]
Thinking of getting light tracer.
I use blender but light tracer seems faster....when you are a one man show ...every minute counts :D
