Looking for some advice.
Read about MoI and like what I have seen so for.
Do a lot of the things I make using Tinkercad, and know that I do things the hard way using that program. Also have a Fusion 360 license but think that I might like the look and feel of this better.
The intent is completely 3D printer based design. Prusa Mk2S and Mk3S for FDM and have a Anycubic Photon on the way after seeing amazing results from a few people I know.
I design items for board games, that compliment, organize, etc.
Best way to learn?
Will this suit my purpose?
I do my slicing in Simplify3D and in Prusa Slicer and can import OBJ files which I understand this software does amazingly.
I have also seen the Tutorial (paid for) videos on one designers site and wonder if those are a good start, or the ones on Youtube?
Finally, for hardware I have full desktop i7 running last year top of the line video cards, tons or ram and SSD.
Also intend to use on a Surface Book 2 15" that runs a 1060 Geforce card, tons of ram, etc.
Just picked up a Surface Go, 10" running intel and 8GB, and was impressed with how smooth this ran on it. That is my only current install as I just started trying the 30 day trial.
How is this software using a pen?
Want to have one piece of software I stick with to create the things I think about in my head, and don't want an interface that I can't grasp quickly but know I need better tools than I am currently using.
Any help appreciated.
"How is this software using a pen?"
You even use only the pen without mouse! :)
Really. That is what I want to do. This is why I bought the Surface Go tablet, highly recommend, as I do a lot of onenote with my company, and wanted to be able to sit down and just take the pen out and be able to work in the software. Is there a good setup for the right button etc?
Normally the Mouse Right Click Button is used for validate the actual function and repeat the last function!
So seems a good thing to make the same with one of your Pen Button(s) ! ;)
Hi Alan, based on your description I'd say that MoI is likely to be a good fit for you. A lot can depend on personal preferences though so I'd encourage you to download the trial version and test it out yourself some to see if it suits you or not.
A good way to get started is to read the introductory section of the help file and watch the tutorial videos which you can find here:
http://moi3d.com/3.0/docs/moi_help.htm
MoI was originally designed to work well with a pen tablet so you can do a lot of stuff with it without using right-click and without needing to touch the keyboard.
Hi Alan,
"I design items for board games, that compliment, organize, etc."
You might want to post some visual examples of what you're thinking of...
...if what you're wanting to design is more "organic" shaped then MoI may not entirely suit your other requirements...
"Want to have one piece of software I stick with to create the things I think about in my head"
HTH, Colin
I can speak to the 3D printer questions, as I've used MoI a lot to design printed parts for my projects.
I also have Simplify3D and use it with my Robo R2 3D printer. I export my parts from MoI as STL files and Simplify3D has always imported and sliced them with no problems.
My projects require good precision as I often press bearings into holes or press 3D printed gears on to motor shafts. Here's a tip: In Simplify3D I scale the part to 100.5% This is to compensate for shrinkage as the plastic cools. Experiment and find a value that works for your system.
Michael.
Thank you for your response. Have read some of your interviews and love the way that you have designed what I have seen so far. I have noticed that your software has some authorized re seller's as well? What is my best path to purchase this? Direct or through your re seller channel?
Love that you have designed this with pen in mind.
If I buy now, I will get upgraded to version 4 upon release?
Everything I have seen so far makes a lot of sense, and there are a set of tutorials on youtube that I have been watching, and depending on how much I dive in, you also have videos you sell correct? Would those be too advanced or are meant to help a person who is comfortable with software just learn where the tools are and basic use?
I have the trial on a couple of my computers and was concerned about how it would work on my Surface Go, and it works very well.
Thumbs up on this Michael.
Once I get up and running I will be sure to write a review that you can use if you want.
Been searching for one program to learn and use moving ahead, and my primary use is for output to a 3D printer.
alan
Here is an example of a case I designed for a board game called Too Many Bones. I am looking to build board game table organizing accessories. Things that make it easier to sort out all the parts in the newer games that are coming out.
Ed.
Great minds think alike.
I use Simplify as well and increase .5 to 1 % depending on fit I need. I understand that the OBJ file format may be even better than STL. Have you tried to import those yet?
alan
Hi Alan,
Well it doesn't really make much difference but often the resellers have a little lower price so that might be best for you.
Yup, we are close enough to the v4 release that if you order now you will be able to get a v4 upgrade for no additional cost. The way it will work is there will be a link on the order page where you'll be able to put in your V3 license key and it will give you a v4 upgrade there.
Actually no, I don't have any additional videos for sale myself. There is a collection of links to other tutorials though at
http://moi3d.com/resources .
Thanks, - Michael
Hi Alan,
Well OBJ format supports a lot more things than STL like it can have materials in it but it is not likely that this additional information will be used by your slicer program.
Also OBJ format supports n-gons (polygons with more than 3 or 4 sides) but it's also not likely that the slicer is set up to handle those very well so you would probably want to use the option "Export: Triangles only" when you export the .obj file.
STL format is the one that is most frequently used for 3D printing data transfer.
If you want to export to a rendering program, that's when OBJ format is better to use than STL.
Yes, correct, it was another user that had some tutorials. I appreciate your response and dedication to your creation. That helps me make my decision.
Perfect. I always work with stl files and thought that if I was getting into multi material use such as colors, that OBJ contained some info such as that color information? Could be wrong. Have a Mk3S that will be getting the MMU2 treatment when it is fully vetted.
Hi Alan, yes that is true that you would want to use OBJ format if you do want to transfer color/material information. There is no way to have colors in STL files but there is in OBJ files.
You probably would want to set "Export: Triangles only" on the meshing options dialog when you do the OBJ export.
