14-27
Hi Pilou, yes on multi-line text there is going to be an option for alignment: left, center, right, or justified.
Here's what it looks like with center alignment:
Cool stuff!
Perfect!
Really good stuff Michael !
I would ask you only, if it is possible to align the dimension description/text above the line like in technical drawings (
https://en.wikipedia.org/wiki/Technical_drawing#/media/File:DIN_69893_hsk_63a_drawing.png ) ?
Thank you,
Mik
Wow, that's great news!
Blocks of text will be very useful.
Marc
Really cool stuff! Thanks for all the hard work Michael!
Hi Mik,
I don't have that one set up quite yet to show off but it is planned.
Thank you, Michael, it would be great.
Mik
Something like that is possible ?
Hi Pilou, no the new annotations won't be for doing something like that, you would need to use other drawing tools (like Draw Solid > Text and Transform > Deform > Flow) to make that type of thing.
Do you have any examples of technical drawings that have a wiggly shape like that?
For more versatility...
It was more purpose for graphic design objects image!
for take advantage of the possibility to draw anything in 3D or 2D! ;)
Of course Flow function can supply of that...but if it's will be in native that will give a little unic speed feature to the prog! ;)
As you draw a straight curve (?) for dimension I could believe that will be automatic to draw a sinuous one :)
Unfortunately no - it would take a lot of additional work to make dimensions able to do that it is very far from being automatic.
No problem the "Flow" will make the trick! :)
14-27
