Show messages: All
1-3
4-8
Hi Keith, I made a quick try like this:
Side profile curve:
Extrude:
Top profile curve:
Boolean difference:
Variable radius fillet:
The way you do variable radius fillet in MoI is select all edges that will be involved in the filleting, then set the main radius, put in the radius that will be used for most pieces. Then to specify additional radii expand the "Fillet set" control inside the fillet's command options, then click "New point set" and pick some points where you want a different radius value. So for example above I picked 2 points one on each end. Then you'll be back to inputting a radius value but now it's a second radius value for this new point set and when I put in a smaller value that produces the variable radius fillet above.
You can also click on the "Current set:" label which is showing what set the current radius value will be applied to. When you do that a menu will pop up and you can switch the active point set or switch back to the main radius value, or delete a point set.
Thanks Michael
I will give it another try when I am back at the keyboard. Thanks for helping so quickly.
Best wishes
Keith
Hi Frenchy Pilou
Thanks for taking time to reply. I have trouble where filets intercept. Micheal has suggested a way below that I will try. In my imagination there was some way of blending surfaces. I have seen people do this when modelling car bodies (
https://www.youtube.com/watch?v=xr6WBeHbzK0). Organic curves is one are where I struggle when using Moi. I think its the place where my brain finds its limit when imagining how to create shapes.
Variable fillet is a little tricky in Moi! You must make a little training!
As you can put any angle along your first general one!
But very funny to make!
Here only one, but you can add any number you want
all was recalculated!
Careful don't press (last) Done till you want add one more!!!
Here a multiple variable Fillets on a same edge! :)
One general with 3 unities angle
Two with 2 unities angle
One with 0 unity angle
When you press the last "Done" edition will be not possible : only CTRL + Z but all will be losted!
Remark that previous fillets will be not visible when you add news point!
So draw Lines Guid for some help! They stay between new adds till the last "Done"! ;)
Show messages: All
1-3
4-8
