Show messages: All
1-7
8-10
Thanks Death. Right on. The test now would be if you could boolean subtract from it now. No matter how I close it, when I try the boolean difference the result is an open mesh.
Thank you Michael - Makes sense. I'm still getting the hang of this, so my models are a bit sloppy.
I will visit the two links you provided. I appreciate the help.
Ok, I think your problem is that you do NOT have a solid when you do the subtract.
I used the surface and then blended the bottom edges (2 opposite edges, 0 Bulge),
then I did the same with the front and back openings.
Now Union the the thing and you get a solid from the which you can Boolean whatever you want...
Show messages: All
1-7
8-10
