Show messages: All
1
2-11
Hi Mark, I do want to improve filleting in MoI but the main route to doing so is to incorporate an additional geometry library and there is a large amount of work involved in doing that. So I'm not certain when that will happen.
Filleting is a very complex operation involving many aspects such as offsetting surfaces, extending surfaces, intersecting surfaces that may be nearly grazing each other and recognizing many different corner junction conditions and filling those in. It is one of the most complex operations in CAD and is not easily dealt with.
Thanks Michael
I can't imagine how complicated it must be, but great that it is on the hit list for some future update.
All the best
Mark.
Maybe this is a stupid idea, but couldn't it be possible to internally use Boolean and Blend to realize fillets that can't be done using the regular Fillet algorithm? Maybe incorporating that as an "Alternate method" checkbox in the Fillet tool.
Regards,
Metin
Hi Metin, unfortunately one of the most difficult things for fillets is handling cases where fillets come together between multiple surfaces. The Blend command is only focused on generating a surface, not on handling juncture areas.
Well, for v4 I'd really appreciate a fillet removal tool. Cleaning up those geometry is still very tedious in MoI.
Nevertheless, for what MoI is intended for I'm still very satisfied with the fillet function.
Hi 3image, unfortunately the geometry library MoI currently uses does not have a fillet removal function, so it will not be feasible for me to implement that kind of tool in MoI v4.
You might take a look at SpaceClaim for that type of function, I think it has a good tool for that.
Any news on a switch to new geometry kernel which will be able to handle complex fillets (like Fusion260, SpaceClaim, etc.), among other things?
Thanks!
Hi klaudio, sorry no news on that currently.
I've asked once to add Points for scripting just for this purpose (to rewrite fillet and shell in js)
Actually, the - for students and hobbyists - (still) free Fusion360 already does that: It's able to remove fillets.
Yeah, I can remember you already mentioned it some time ago, so I can understand that situation. But still, I think a new solid kernel is a must for the next version (v5 since we are already at v4 :-D ).
Show messages: All
1
2-11
