I import and resize a lot of objects and I wish to select a solid then use a keyboard shortcut to open the edit size flyout with either the X or the Y highlighted
perhaps a second keypess to toggle between the x and the Y
is this possible ?
Many thanks
shayne
Hi shayne, if you set this up on a keyboard shortcut it should launch the edit size flyout:
script: /* Show edit size menu */ var pp = moi.ui.propertiesPanel; if (pp.show && pp.numSelectedObjects > 0) { moi.ui.findElement( 'PropSizeContainer' ).onmousedown(); }
When the flyout is open you can just start typing numbers and keyboard focus will automatically go to the first field. You can also press Tab to put focus on the first field and also use Tab to move focus to the next field.
Hope that does what you want!
Thanks Michael
I am using ver 3 and get this error
thanks
shayne
Hi shayne, sorry yeah that one needs v4. Here is a version that should work with either V3 or V4 :
script: /* Show edit size menu */ var pp = moi.ui.propertiesPanel; if (pp.show && pp.numSelectedObjects > 0) { moi.ui.sidePane.PropSizeContainer.onmousedown(); }
Thanks Michael
perfect
cheers
shayne
