13-32
33-35
Hi Lara, please see the attached 3DM version for a replacement for your red surface.
The way I made it was not by directly lofting between that upper and lower edge but instead extruding this one downwards:
So that makes a very regular shaped and extended surface like this:
Then trim it with this to slice the bottom chunk off:
So often with NURBS modeling you don't want to try and build a surface that directly hugs along some irregular shaped boundary, it's often better to build a simplified and extended surface sheet which then gets the irregular boundary applied to it by a trim or boolean cutting operation. That's the main way to get higher quality surfaces, when you trim a surface the surface shape stays the same and it just gets new trimming boundaries on it marking which areas of the surface are active.
Hope that makes sense!
ArtForumMOI2.3dm
Hi Lara, also I just noticed a couple more of those "squished down surface" pieces in there. Another way to get rid of those is to select your main object, and then on the side pane go to Select > Invert which will invert the selection and get the degenerate surface pieces selected so they can be deleted.
A click on a degenerate surface (meaning a surface that is compressed down so it has no actual surface area and looks like it is just a line or a curve) will not select it but other means such as a window select or invert selection or using the scene browser can select those.
Those are usually not things that you want to make, but you can end up with them if you do something like maybe loft between 2 identical curves or if you accidentally squish down a surface so it's all compressed.
@Lara
Still just a simple Boolean, just with an offset object...
Instead of trying to "melt" 2 objects together, try 3. Space them apart, insert the bridge object you want, Boolean the whole kittenkaboodle and then fillet to desired width.
Goes like this: Draw your first box object, rotate it holding the CTRL key (gives you a copy). Move the boxes where you normally would, only leave space for twice the fillet size you want, then make a bridge object to match (another box). You now have three boxes which you need to "Boolean Unite" and then fillet. Done..
13-32
33-35
