Show messages: All
1
2-6
Your objects are "tangent" just increase Scale 1D and that will works! ;)
Thanks so much Pilou!
Just tried Larger and smaller and works!
Hi JoeZ, it sounds like you've got it figured out, but yes it can be difficult for booleans to handle cases where 2 surfaces are just barely skimming each other with overlapping surface areas. That's a more difficult case for surface/surface intersection to handle.
So it is good to push objects through each other with a little clearance if possible.
Thank you Michael!
And thanks for this forum!
I appreciate all the support!
I've learned so much, reading the post in it, almost daily!
Same for me Jose, this forum is a goldmine :)
Show messages: All
1
2-6
