Full Version: How to print outline of objects
Show messages: All  1-2  3-12
8 Mar 2019   [#3] In reply to [#2]
Thanks for the link Stefan - I'll check it out.
I'm not necessarily looking for a program to unfold my entire model.
At a more fundamental level I'm curious how to print the flat outline of a single plane that is tilted in two directions.
8 Mar 2019   [#4]
Hi Ed,
would that something better?
https://www.youtube.com/watch?v=f3L0G6giO1k
8 Mar 2019   [#5]
You have the Free FormZ Free who has an Unfolding function inside! ;)
Minute 24
8 Mar 2019   [#6]
Thanks for the links guys.
I think an un-folding program is over-kill for my simple model. I'm happy to deal with one plane at a time.
Isn't their a way in MoI to click on a flat plane and make the MoI "camera" look at it head on?
8 Mar 2019   [#7] In reply to [#6]
If I understand you correctly then aligning the Cplane to each of plane of your model should do what you want.
Colin
8 Mar 2019   [#8] In reply to [#6]
Not exactly that you want but...
Camera&TargetPointToClipboard – it will copy the camera and target locations to the clipboard as a text string:
F9 script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + v.cameraPt.toString() + '\r\nTarget=' + v.targetPt.toString() );
Similarly you can set the .cameraPt value to something to place the camera at a certain x,y,z location:
F7 script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.cameraPt = moi.vectorMath.createPoint(50.2, 30.5, 10.1);
8 Mar 2019   [#9] In reply to [#1]
Hi ed, so for a simple case with just a few pieces there would be 2 main ways to do it.
#1 is like Colin writes above - use View > CPlane to set the construction plane to the center of one of your angled planar shapes. This will relocate the Top/Front/Right views to that local frame of reference and now when you export a PDF, AI, or DXF file using the Top view projection it will be a straight-down view on that particular plane.
#2 is to dissassemble your object using Edit > Separate and then use Transform > Orient to relocate each face onto the world xy plane.
8 Mar 2019   [#10] In reply to [#9]
Thanks everyone!
View > CPlane on my tilted plane and exported as AI from top view. Opened the AI file in Corel Draw and have a flat, actual size outline ready to print and use as a cutting template.
8 Mar 2019   [#11] In reply to [#10]
Hi Ed, so just for future reference the other disassembly method using Transform > Orient is pretty good too, since the orientation picker can be aligned to a surface normal for the base position and the world z axis for the target position.
That looks like this:
8 Mar 2019   [#12] In reply to [#11]
Thanks Michael. Good to know.
