19-38
39-58
59-62
Hello Michael,
can you advise please how to change the color and style of the main frame that divides the right / left / top / 3D views from each other.
I used Cody's dark theme which was really nice but since the css is not customized for v4 I would use the css files you modified for v4 of the dark themes from other users, but there the frames are default light grey.
Axel
HI Axel, that's one of the few remaining areas that is still drawn by a bitmap image instead of drawn procedurally by code. So to modify those colors you need to edit the file ViewportForeground.png in the UI folder using an image editor.
thank you for your advise.
Best regards,
Axel
...what a difference with a dark frame. It was very easy and the dark theme looks much better in my opinion with the dark frames. It fits nicely.
Cheers,
Axel
19-38
39-58
59-62
